(UK) Would it be hard for a sex offender to become an electrician and keep a job? | Page 2 | on ElectriciansForums
Discuss (UK) Would it be hard for a sex offender to become an electrician and keep a job? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
England
These are for charges relating to when I was young and dumb but I now have to register as a sex offender for life with an indefinite SHPO. I'm not seeking any forgiveness.
I'm looking to become an electrician or something within the trades but I'm worrying whether I will have trouble finding work as one due to my charges.
Any help is appreciated.
The type of offence, being what it is, has a serious stigma attached to it.
Being blunt but not judgemental, for my sins I believe in rehabilitation and second chances, I personally would not employ you purely because of the damage to my reputation if and when it became public knowledge as I work predominantly in the domestic market.
Working in the industrial sector may be different but I would suggest that your options would be limited to being employed by a company where you are in a single location I.E. a factory or similar and not for a contractor where you would be sent to various locations.
Everyone does stupid things to varying degrees when young. Learning from it and not repeating the behaviour is the important bit.
As hard as it is I would suggest being open and honest with potential employers as dishonesty on something like this could cause some very serious problems for everyone involved.
If you have to disclose it to every employer then would that include people who employ you to do self employed house work?
if so that would make domestic work hard.
If you can put yourself through college, you could get the college qualifications then a big obstacle would be finding someone to take you on for the on-site part to become qualified.
Maybe apply for apprenticeships with big companies, so power companies like western power, water companies, national rail etc. Be honest in the application forms and see what happens.
I would think that I have to do it for self employed work yes.
I would still very much like to get into the trade but I wouldn't like to go through college and apprenticeships and go through several years of training and become qualified just to find out no one will hire me despite it.
I would think the only way you would get trained in the type of work you could do would be through an adult traineeship with the type of employer mentioned in posts 15 and 16.
Domestic and self employed work is pretty much out of the equation.
OP here, without going into too much detail, it was an online offence where I communicated with several teens when I was 18. My SHPO means I must disclose my offence to any potential employers.
So I assume becoming an electrician is a no-go? Would this even be for commercial rather than domestic?
I did say you didn't have to explain yourself. You've recognized your faults and moved onwards. In times, not so long ago, in your circumstances, many have done something very similar. This is the millstone our now society requires you to carry.
But you can move on, don't take the narrow view here, as representative of prospective employers. It will be hard for you, but don't loose faith, as you turn your corner in life.
Good luck @pqowieuryt
Think as mentioned an internal apprenticeship with a big company might be your best option. Would be awful to do all the college work to be knocked back. Speak to the job centre or maybe a support worker about it as they will have more idea probably than us on here.
If you manage to get a job with a company and they then have to declare you to all clients and building sites you work on, sorry you have no chance. You wouldn’t want to be on a building site with lads knowing you have that hanging over you either.
I think the issue of people judging you because of this will be universal to any job, not just to being an electrician.
I think that once you have found an employer who can see past this and give you a chance then you will be fine. Obviously you still need to work hard etc etc but that is universal to anybody not just your situation.
There will be some places you won't be able to work, care homes, schools etc etc but I'm sure you know that already, so do a bit of research in to companies you are applying to and avoid companies that do a lot of that kind of work.
Have you considered getting the SHPO discharged by applying to the court, if it was such a long time ago etc etc,
I think that is an option that you should consider, only you will know the full circumstances around why you were put on the register and I'm guessing there may have been some input from people who specialise in this field at the time.
Certainly for most jobs a standard DBS will be required and for others an enhanced DBS which includes a police check on records that they hold.
You can make a request for what types of work you will be barred from doing but I would agree with what others have said anything connected with schools, hospitals, care homes, etc., is unlikely to be very favourable towards you.
When completing the questions in the 'Safeguarding' section of the application form you will need to declare all UNSPENT criminal convictions and cautions that are not PROTECTED (i.e. eligible for filtering) as outlined in the Rehabilitation of Offenders Act 1974.
Employers:
  • will consider any criminal record information on a case-by-case basis
  • only take into account information that is relevant to the position you are applying for
  • balance this information against the skills and competencies you have demonstrated in the recruitment process
  • balance this information alongside other information they have obtained about you as part of the pre-employment check requirements
  • must not ask applicants for details of, or consider any convictions or cautions that have become spent, as part of their recruitment processes
  • align to the Code of Practice issued by the Disclosure and Barring Service (DBS), which sets out what employers need to consider when criminal record information is disclosed in a DBS check
If you declare information that is relevant to the role you are applying for, employers will take into account:
  • the seriousness of the offence(s)
  • your age when you committed the offence(s)
  • the length of time since the offence(s) occurred
  • if there is a pattern of offending behaviour
  • the circumstances surrounding the offence(s)
  • any evidence you provide to show that your circumstances have changed since the offending behaviour.
The criminal justice system is complex and often difficult to understand:
  • You need to be clear about what information may be included on your criminal record,
  • what you need to declare to any employer you may be working or volunteering with, and,
  • your legal rights when doing so.
If you are unsure whether you have a criminal offence that needs to be declared to an employer, would like advice about how best to declare criminal record information or your rights, the following charity bodies offer free, independent and confidential advice:
Nacro
Tel: 0300 123 1999
Email: [email protected]
Unlock
Tel: 01634 247350 (Mon-Fri 10am – 4pm)
Text or WhatsApp: 07824 113848
I think everyone deserves a fair crack at the whip, but to be honest, I think you’re going to struggle. I’m not hear to judge you, but the very nature of the offence you’ve committed will put most people off, myself included. If you’d been in a drunken fight 15 years ago and had a conviction for ABH / GBH and not been in trouble since, then I think most people could forgive that, I know I would as can relate to it.
An old school chum of mine had a relationship with a girl a few school years below him. Some years later they got married, had kids and he’s now a grandfather. Should we now have his crime, reinvestigated and for him to be put on the sex offenders register, for the rest of his natural.
Don’t get me wrong, totally against the sexual exploitation of anyone including young children, but in this instance, as far as we can be informed of a forum, it’s on the lower end of the scale.
I don’t see why we can accept someone who has committed serious assaults in the past has reformed, whereas in this case we cannot.
Probably because every one of us has at some point punched or seriously considered punching someone.....a crime involving children especially this type of crime is not something most people can relate to and don’t even want to think about...I don’t know the details and I don’t want to....And rightly or wrongly people do not want to be associated with it...on a personal level I wouldn’t employ a drunk driver either
There's a distinct difference between marrying your childhood sweetheart years ago when attitudes were different, and doing something that warrants getting a SHPO by today's standards.
After having done jury service in December and sat on a sex case where someone was up for breaching one, i know that SHPO's aren't dished out for minor offences; they're given to people that are seen as an ongoing threat / danger to the community, which is why they issue them. I.E. serious and prevalent offenders that can't be trusted to go about their day to day business without being a nuisance to the public.
It's also no secret that looking at stuff you shouldn't be looking at on the internet, or speaking with underage girls on the internet, will get you into a serious amount of trouble; and rightly so. At 18, you're an adult, you know the difference between right & wrong!!!!
Now compare doing something like that on multiple occasions willingly, to punching someone once while intoxicated while on a night out; and i know which person i'm willing to forgive and give a job to.
People can agree or disagree, but those are my standards and i'll stick by them thanks.
We don’t know the details, but I believe we are not talking about young children, so let’s keep the comparison in check.
As to giving preference to someone (a job) whose just punched another whilst intoxicated is debatable. Might ask my son, who was punched in the face, and broke his jaw in two places. He suffers problems and pain, from the rusting of plates put into his jaw, to fix them. His crime was he didn’t have a cigarette to offer his assailant.
So I can’t agree with that analogy.
Have to agree with this. Too many people use drunkenness as an excuse to dismiss all manner of unacceptable behaviour. Alcohol doesn't make people violent, it simply lowers their inhibitions and an angry or violent person becomes less able to suppress those urges.
Status
Reply to (UK) Would it be hard for a sex offender to become an electrician and keep a job? in the UK Electrical Forum area at ElectriciansForums.net
