Unbelivable! | Page 3 | on ElectriciansForums
Discuss Unbelivable! in the UK Electrical Forum area at ElectriciansForums.net
High Tower
Nearly Esteemed
Birmingham
So, popped into a large national estate agents that i work for, to add a couple of sockets for them, simple job, nice and easy with a early finish.
The board was changed and a PIR done in 2010, the companys policy is no codes are acceptable, has to be a clean pass. that in mind have a look at what i came across, the original contractor was a big firm based in Nottingham. no wonder they are always cheper than us!
[ElectriciansForums.net] Unbelivable!
Cheap crappy CU with 3 blanks missing
Ip Rating compromised
Trunking really has seen better days
6mm2 gas bond on a 100A supply and abandoned switch gear still live
Perfect connections to the time clock!
Is there anything that people wont use a 951 clamp for?
hmm....
another `dummy` outfit then...
Your all thinking along the lines of using the pressed knockouts. Why, if you need to maintain IP values, not use stuffing glands, they are available for flat cables as well as the normal round cable. OK you need to drill your entries into the CU, but how hard is that?? ...It's not as if you'll need to do this on every CU you install, only those that for one reason or another, requires an IP rating to be maintained!!
E54, all enclosures require a minimum IP rating to be maintained. It's not just about dust and water ingress, but about preventing access.
BS7671 Amdt 1, 416.2.1 and 416.2.2 require IPXXB or IP2X on all faces and IPXXD or IP4X on accessible top surfaces.
E54, all enclosures require a minimum IP rating to be maintained. It's not just about water and dust ingress, but access to live parts (which is what we're talking about here).
BS7671, Amdt 1: 416.2.1 and 416.2.2 say that all surfaces to be at least IPXXB or IP2X and accessible horizontal top surfaces to be at least IPXXD or IP4X.
Edit: Sorry, just spotted the double post. The first one appeared not to work.
Reply to Unbelivable! in the UK Electrical Forum area at ElectriciansForums.net
