Understand pricing of a job - labour and materials | Page 2 | on ElectriciansForums
Discuss Understand pricing of a job - labour and materials in the UK Electrical Forum area at ElectriciansForums.net
East Midlands
Hi, I wish to get a rough estimation of how much a job should cost considering the UK:
Supply and install 44 Led downlights in ceilings
Rewire 9 of these downlights in a single room after changing their position
Move a single switch from outside a bathroom to inside replacing the existing light with a bathroom light and pull cord
Change an upside down socket to the correct way round
Replace 25 sockets with normal white sockets
Replace 10 switches with normal white switches
Install 3 wall lights
Install an RCD
Earth the boiler
Run a test
I would be interested to know man days and approximate range of rates.
Any guidance much appreciated
£5200 as it sound like its not going to be straight forward .Lots of work around so charge more for the jobs you dont really need .Its not no one is out of work these days !
This seems quite a common thing these days. Busy contractors are whacking up the price on small jobs , fiddly jobs and jobs they don't really want. But if they get the job then at the inflated price is worth the ball ache...
I had a fencing contractor last year quote me a small fortune for a new fence, presumably as they didn't really need the work. so I did it myself / paid a labourer a day to help me do the digging out etc. I think their quote as just shy of £2000, I did it for about £500 including £200 cash for the labourer
No one wants hard /fiddly jobs or customers who are going to be trouble .pricing the job high gives them a way out and if they accept. There is enough on top to make it worth it etc
Thanks, that's fantastic. Electrician's certainly are expensive these days
Simple solution Dogstar, you become an electrician and show us how it's done for less, once, that is, you've spent a decade becoming competent and tens of thousands setting up your company. Flippant cheek like this drives me nuts. We're a specialist trade, it costs a lot to BE an electrician.
Reply to Understand pricing of a job - labour and materials in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
