upgrade meter tails, or downgrade main incoming fuse?? | on ElectriciansForums
Discuss upgrade meter tails, or downgrade main incoming fuse?? in the UK Electrical Forum area at ElectriciansForums.net
M
martinsayer81
hi guys
hoping you could give me your thoughts,
i am pricing for a consumer unit change, its an old fuseboard with re-wireables.
it has 16mm meter tails, but it has a fairly new looking 100A main fuse.
its a small-ish house..... 2 ring mains, 2 lighting radials, a couple of sockets in the garage, and an immersion heater radial,
i was wondering whether or not i could just down-grade the main fuse to a 60A and keep the existing 16mm tails( no damage, or signs of overheating or burning)
or whether i have to leave the fuse at 100A and fit 25mm tails?
there's no electric shower or oven,
i would appreciate your advice
many thanks
as above^^^ it may say 100A on the outside, but be a 60A fuse on the inside. just leave the 16mm tails in, and the fuse is not your responsibility.
As #2 & #3 the 16mm tails were probably installed by the DNO along with the fuse, I would be more concerned that the earthing and bonding was correct for the supply characteristics
its the dno 100A fuse,
at the moment i am just going on the sticker on the outside, it was late in the evening when i looked at the job, and couldnt pull the fuse to check,
wouldnt it be against the regs to leave the 16mm tails with a 100A fuse?
i just dont want to get any come backs
The OSG pictures assume you are working on a new build....
Do they have 3 electric showers, multiple cookers, a canabis factory in the loft..... The usage for a house is unlikely to rise about 35 amps so I'd leave them welll alone.
so, basically, if it does turn out to be a 100A fuse in the holder, it would still be ok to leave the 16mm tails due to a low demand?
Reply to upgrade meter tails, or downgrade main incoming fuse?? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
