upgrade quote | on ElectriciansForums
Discuss upgrade quote in the Business Related area at ElectriciansForums.net
R
richy8ball
new fuse board with 5 circuits plus bonding, wiring a radial and lighting in the garage all surface, changing 4 light fittings, turning 10 single sockets into doubles, adding 3 extra sockets on the ring. wondering whats a fair price for this work?
What Biff said.
It's nearly impossible to price a job accurately without seeing it first.
In the same way you wouldn't be able to give a price for a job like that over the phone, nobody here can help you with a comparative price.
Fuse or MCB / RCBO, 5 existing or including the new circuits, easy access, D.N.O isolator?
plus bonding
what size and distance and method of fixing, surface under floor in ceiling ,?
how far from C.U how big is garage, how long are the cable runs, timber, brick concrete sectional ?
LED, pendant, decorative, external spots / floods ?
surface boxes, flush, brick block plaster, or board or eggbox or straw walls, cheap sockets, screwless, designer?
adding 3 extra sockets on the ring,
how far from existing sockets, what sockets, cheap, screwless?
Are you VAT reg?
Somewhere from ÂŁ350 to ÂŁ1800,, possibly??? + Vat, possibly
It all depends on how much time is needed to add the 3 sockets to the ring, wire the garage, and install the earth wires to gas and water. The board cost and replacement 10 single to double sockets are fairly easy to price, changing 4 lights also fairly straight forward, you need to see the job to estimate whats involved with the labour for the wiring aspect.
It certainely sounds like 2-3 days work, and thats the thing here with this Job, whether it is 2 or 3 days????????????????
Work out material costs add 15% then charge for your time, don't forget it all needs to be signed off to comply so if your not niceic or any other governing body allow an extra couple of hundred pound for building control :)
Reply to upgrade quote in the Business Related area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
