Upside Down UK Plug Socket - Is This Normal/Ok? | Page 2 | on ElectriciansForums
Discuss Upside Down UK Plug Socket - Is This Normal/Ok? in the UK Electrical Forum area at ElectriciansForums.net
Grimers
Exeter, UK
Hi all,
Just recently moved into a renovated house in the UK where a desk is quite high, so the plug socket above it has had to be put in upside down! Other than a bad case of OCD, is this normal/ok?
Please see attached photo.
[ElectriciansForums.net] Upside Down UK Plug Socket - Is This Normal/Ok?
Cheers,
Will
If keeping the socket upside down, I recommended putting something under it to catch the electricity that falls out.
No need to. It'll just form a puddle on the top of the desk. If the desk wasn't there then I agree that you would need something to catch it. I would use a plastic takeaway container. Don't use one of the foil ones as you could get a shock if you didn't ground it before emptying.
Foil containers should be grounded anyway. Surprised you aren't aware of that. :)
Is this really ok? I’m concerned that if we use it then there could be issues.
Provided no cables are strained, etc, it is fine, just unconventional. FYI the sockets on some trains are that way for the same sort of reasons, just labelled to explain it!
If it worries you then a lower desk, or some spacer so it is not hard against the wall, would allow a conventional solution.
Thanks, unfortunately we can’t lower the desk as it’s fixed. We will sort it one way or another!
Thank you also. Can you link to what this is? Sorry, I’m in the IT not electrical trade! 🤣
Then two single sockets on their (opposite) sides, linked through (probably you have cable in to one, link to next, out to rest)
Also please get a socket tester of some sort for any work!
Thanks. I definitely wouldn’t attempt anything other than rotating what’s currently there myself!
Well, the socket seems to work fine and have actually found that there is less strain on the cables with the socket orientated this way. The socket is hidden by a PC monitor now, so at least we don't have to look at it!
Reply to Upside Down UK Plug Socket - Is This Normal/Ok? in the UK Electrical Forum area at ElectriciansForums.net
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
What is the distance from the point outside the house to the shed?
