Urgent: 60 amp main cut out fuse required | Page 8 | on ElectriciansForums
Discuss Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
Is this really still going on! Customer has power you have your money everyone's a winner. Just 2 pieces of advice
1-don't pull the bomb again
2- if you do don't tell anyone,
but I'm sure everyone on here can keep,a secret not like you've broadcasted it on the Internet
Unless you're in a SSE area and you have their temporary seals. In which case, you can pull the fuse with impunity.
It's a good system; all the DNOs should do it. Then we wouldn't have all this fuss.
If you read it I think you'll see the fuse was blown when I arrived and it was because there was a extension lead outside full off water!!!!!
There only 2 reasons for pulling that fuse. 1 for isolation 2 because the customer has no power and the rest of the road has so I think it should be removed to check.
Or should I just walk away and tell them to call the dno.
I can't believe some of the crap you guys post.
I turned to you lot to ask for some help at 11 o'clock on a Sunday night realised they'd blown the main fuse. I didn't have a 60a, only a 100a.
Something that could have been sorted fairly swiftly.
I though u lot might be the type to help a fellow spark.
Maybe not
Anyway happy customer (with my service) lesson learned by them.
All back and running by 8:30am
So it took you from 2300 to 0830 the following morning to source and replace the cutout fuse ?????
the DNO has a max response time of 4 hours to replace the fuse and it would have cost the customer nothing.
You should not have messed with DNO equipment. All you needed to do was a quick insulation test on the customers side to make sure their was no fault that had blown the fuse at most and walked away (after calling DNO) anything more was a complete rip off.
what was the final bill for your excessive time spent messing about trying to find a fuse that you had no place changing. Not to mention the extra time the customer was off supply.
yeah......its just totally stupid....
too much of it comin in here now....
ÂŁ189 including vat which the customer paid to the third party for my attendance.
I stopped looking for the fault finding due to the rates they were paying, and the fact with no fuse immediately available I could not walk away knowing everything was sorted.
Waiting for the dno Knowing the fault still existed, I returned in the morning with a fuse ÂŁ4. Continued the fault finding. Found fault.
Customer could have sat up all night waiting for dno, and saved ÂŁ4 but still wouldn't have known why it went.
I charged ÂŁ40 for my time in the morning.
Granted I could have found this fault in the evening but that extra time prob would have risen their bill with the third party.
As you can never be sure just how long a fault will take to find I wasn't happy to do this.
I also wanted to see the installation live as part of my agreement with the third party is to return at no cost if the fault is not fixed.
So if I had found the fault I couldn't be 100% sure.
It's an hour in Cyprus!! lol!!
Iv'e had reason, to call them out on more than one occasion over there, (not for my own properties BTW) and never had to wait more than 30 minutes!!
And the point been their was a fault and finding it at the rates been charged could have resulted in a higher bill.
Walking away after billing for
My time saying call the dno would have resulted in me coming back anyway when the fault re-occurred.
At least keep you story straight. Earlier you said it was a extension lead full of water. So did you find the fault or not?
Still at least you managed to get a good christmas drink out of the customer needlessly.
Reply to Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
Apart from how you extend all the cables
Thanks for your feed back re- G99 SGI paper work i be file again. SSEN G99 SGI-1 fasttrack
