Urgent: 60 amp main cut out fuse required | Page 6 | on ElectriciansForums
Discuss Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
how many home owners are there in the UK with 3036 rewireables, that wouldn't know a EICR if it jumped up and bit them in the arse? ( the home owners, that is, not the fuses )
just scrollin through some of this....
seen some beautys n all....such as
someone goin on about pullin bullits under load.
quick fixes with 30A fuse wire in parallel (2)
just thought i`d mention that the service head is DNO property.....so get them to come and sort it...
at least someone bothered to ask the obvious: why did the bullit operate in the first place?....
i think someones been buggerin about with that cutout myself......
If you read it I think you'll see the fuse was blown when I arrived and it was because there was a extension lead outside full off water!!!!!
There only 2 reasons for pulling that fuse. 1 for isolation 2 because the customer has no power and the rest of the road has so I think it should be removed to check.
Or should I just walk away and tell them to call the dno.
I can't believe some of the crap you guys post.
I turned to you lot to ask for some help at 11 o'clock on a Sunday night realised they'd blown the main fuse. I didn't have a 60a, only a 100a.
Something that could have been sorted fairly swiftly.
I though u lot might be the type to help a fellow spark.
Maybe not
Anyway happy customer (with my service) lesson learned by them.
All back and running by 8:30am
Quote
Would that be "In future ring the supplier" lol
But the customer didn't know the fault, they also didn't know the main fuse had blown
and the dno wouldn't have found out why the fuse had blown
Lesson is dont put non ip rated stuff outside...
The only thing gain from calling the supplier would have been a saving of ÂŁ4 for a fuse. And there would have been a lot more time waiting for them.
Maybe not
Why didn't you just use you voltage tester on the DB?
Good luck with explaining to the DNO why you replaced one of there fuses.
Most if the guys on the ground who work for the DNO couldn't give a ---- about seal cutting and fuse changing, they really don't care, I've had DNO out 15 times last two years for various things, never any questions and as explained in another post I've even had them hand me a load of old 60 amp fuses and seals so if I find one blown or blow one I can "sort it myself", could see a huge problem if you tried to change the fuse size however
Maybe not
If your happy to test a fuse by just measuring a lack of voltage
Good luck to you
Good luck to you
If you test for voltage across the main terminals at the cu(or at the isolator if fitted) and you have non then anything before this is a DNO problem,I think the posters who were against pulling the main fuse were trying to warn you in case anything went wrong and you were injured,think about it this way you remove the fuse and something goes wrong and you get hurt then you have no claim against DNO as you should not have been tampering with their equipment.I was in a pub over in yorkshire some years ago and the lights were flickering,the landlord said it had been going on for a while and would I take a look while I was there,I diagnosed a loose connection in the cut out and rang the dno,The flash was quite spectacular as the unit went bang as he tried to remove the fuse.Ended up having to fit a new cutout and repair the cable,hate to think what could have happened if I had tried it myself that day,maybe I could have got the bill.
Good luck to you
As Phil says if their is no voltage at the nearest point to the cutout then there it is the responsibility of the DNO.
The DNO would be round pretty quickly to repair it and not have to ask on a forum for a fuse. Normally they won't charge for it neither still I suppose you managed to charge them for a new fuse fuse a few hours work and made a tidy profit ripping someone off.
The point been the dno would have replace the fuse but not found the fault.
If I just left it to the dno then they still would have had a fault.
I personally like to be their to make sure once the fuse was replaced they had no problems. So For me this was worth it.
Due to the day and the fact the customer was a fair distance from my home, and the customer was planning to up root the family to have christmas at a family members, waiting for the dno seamed a second option to picking up a fuse and replacing it.
Maybe there wasn't a fault and an old main fuse simply gave up the ghost. It does happen.
the point being robert that you
interfeared with DNO property!!
so just take the hint from `us lot trying to help a fellow spark`........get me drift?.....(try #78 for a memory jog if not)
its a no brainer really.....
mind you....at least its not as bad as someone telling me how they `moved the suppliers metering equipment outside` ..recently to....`make room`.....
jesus wept..
Reply to Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
Apart from how you extend all the cables
Thanks for your feed back re- G99 SGI paper work i be file again. SSEN G99 SGI-1 fasttrack
