Use of tie wraps and bunching conductors in DB's | Page 5 | on ElectriciansForums
Discuss Use of tie wraps and bunching conductors in DB's in the Commercial Electrical Advice area at ElectriciansForums.net
DB's in Aussieland are a dream. Cable ducts throughout the boards to prevent individual conductor grouping and looks asthetically pleasing!
Seems like everyone only concerned about overheating factor alone.
As close as you can get in new Regs book and what I think OP meant is a new Regulation (521.200) giving requirements for the methods of support of wiring systems in escape routes.
Apparently to protect fireman. Your cable ties will not comply.
metal tywraps comply
In the properties I own the electrician I use to rewire always allows free space around the conductors as far as is practicable but provides one small cable tie around each of the 3 pairs of conductors of the final ring circuit so that the wiring for each ring circuit is clearly identifiable. This helps him when he does regular inspection and testing for me and any possible erroneous mix up of them. He uses a different coloured cable tie for each frc.
Very strange thing to do, as in domestic properties especially you don't see the length of cable, unless in your houses they are clipped direct on the walls...
Leaving aside stainless steel cable ties for a second, how would cable ties inside a distribution board lead to collapse and entanglement? Surely the distribution board will contain the wiring system!
Reply to Use of tie wraps and bunching conductors in DB's in the Commercial Electrical Advice area at ElectriciansForums.net
The ads are a temporary glitch, hopefully.
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
