well, i would always use 6mm , method C, up to 9kW.
Discuss Using a 8.5KW shower on a 6mm circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Goody, do you post a question on here for every job you do?
If your customers were ever to see your posts you'd never work again
In the OP it states 230V. Using 230V it works out at 6.22 ÎŹ. Use that with 240V and you will get 38.5A.
Nobody has changed ohm’s law. Same resistance with a higher voltage gives higher current. Simple?
Is the point of this forum not to seek advice?
As if I'd have dinner with a Lib Dem
Seriously
That's a pity, as they may have more sympathy for you views. Remember, Part P came about as a result of Jenny Tonges' (Lib-Dem MP at the time) daughter being killed in an electrical accident. Jennys' private members bill proposed a full blown statutory system under one registration authority, similar to Gas Safe. However, amendments added by Labour and Conservative MPs who were lobbied hard by the NICEIC, ESC, Unite and other vested intrests resulted in the castrated system of Part P we have now.As if I'd have dinner with a Lib Dem
Seriously
Reply to Using a 8.5KW shower on a 6mm circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
