Using a 8.5KW shower on a 6mm circuit. | Page 3 | on ElectriciansForums
Discuss Using a 8.5KW shower on a 6mm circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks, folks for all your inputs on this. I simply asked for opinion from other "SPARKIES" and there was quite a mix of suggestions.
I see no point arguing with grumpy ones; utter waste of time.
Thanks again!
Now that the OP has his answer, this will be closed.
Mr Dunlop.
If you do not wish to help another member of the forum, move on to another thread.
We do not have time to keep moderating posts that are unhelpful and insulting.
Reply to Using a 8.5KW shower on a 6mm circuit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
Do you have an iPhone? If so you can take scans that “flatten” the image through some technical magic via the Notes app, these are auto saved as...
