Using SWA cables in parallel | Page 2 | on ElectriciansForums
Discuss Using SWA cables in parallel in the Talk Electrician area at ElectriciansForums.net
Have you tried sizing it with three cables. Another thought does the armour have to support main protective bonds upstream.
Was going to say are you installing a separate cpc (half the line conductor using table 54.7) or using armour as cpc?
What is this supplying? With the info above id lean twoards 2x 95mm 4c
Each cable needs the appropriate correction factors applying first before adding together if using in parallel. volt drop and making sure zs is low enough for the protective device needs considering also.
There will be a separate cpc installed to achieve the maximum Zs for the mccb. The supply is for a unit that will be effectively rented so no idea what sort of load it will be.
Do you know the mccb max zs from manufacturer, as this may be the big influencing factor to what size cable(s) you need to install as 100meter run and 300 amp supply is rather large.
The Ze was 0.09 I'll have a look when I get in the office buts it's a 400A Square D MCCB set at around 0.8 mulitiplyer to give 300A I have a feeling it was 0.37
You need to apply a tolerance of +20% using a mccb for max zs giving a multiplier of 1.2
See beama guide to low voltage circuit breaker standards.
It's a good download to give good guidance.
What's the tolerance of 20% for? I'm really thinking the 2x 95mm are going to be a lot easier than a 300mm2
It's the tripping characteristic of the device.
Manufacturers may state lower tolerances that's why it's best just to ask the manufacturer
Reply to Using SWA cables in parallel in the Talk Electrician area at ElectriciansForums.net
Sounds more positive.
