Using SWA cables in parallel | Page 3 | on ElectriciansForums
Discuss Using SWA cables in parallel in the Talk Electrician area at ElectriciansForums.net
I have found on their website what they state the maximum Zs at max- 0.968 min- 0.052
Is it a nsx 400 micro logic 2.3?
I have zs times from Schneider which is square D now anyway.
You need the isd short time setting which will be on the device.
For example an (isd)Im short time setting of 1.5 is o.33 ohms.
Isd of 10 is 0.050 ohms.
If you've got your info from an old Square D site it maybe more accurate tho as mine is Schneider.
Reply to Using SWA cables in parallel in the Talk Electrician area at ElectriciansForums.net
Sounds more positive.
