UV stable cables | Page 2 | on ElectriciansForums
Discuss UV stable cables in the Talk Electrician area at ElectriciansForums.net
Reply to UV stable cables in the Talk Electrician area at ElectriciansForums.net
I think his modem has switch ports that he is extending through the building wiring, that is what i think is happening. As already mentioned it...
Yes, you run each socket as a point to point connection, and use a switch (it doesn't need to be PoE unless you are wanting to power devices via...
