Guest viewing limit reached
so checked the passenger and drivers footwell areas for fuses and there isn't any there. but wiring loom does seem to chase down left hand side plastic side cover going underneath the door I wonder if there is something behind that ?
so have stripped out glove box and steering column covers exposing both sides of footwells and have disconnected and removed the android stereo. turn on ignition and still no display on head unit or any of the other controls lost like boot loading aid
right have removed steering column cover and footwell cover both passenger and drivers sides and removed glove box and can see no fuses in those areas. but the wring loom from the stereo does run down the left side of the passengers foot behind the cover that runs under the door. could there be fuses behind there ?
Not sure if youve fixed this yet but it definitly sounds like you have a problem with the CAN bus. I dont have the wiring diagram for your car but its normally one pair of wires (CAN hi and CAN low) that runs between all modules. Either this is broken somewhere or its shorted together or to ground. One of the xomputer could also be pulling it down.
With the battery disconnected you should get about 50ohms between the two can lines.
it did register these faults prior to failure even though they are not currently present
B2535-00 Rear Fog Light Circuit Malfunction
B2545-00 Rear Left Reverse Light Circuit Malfunction
B2570-00 Trunk Lamp Circuit Malfunction
B3880-00 Rear Right Reverse Light Circuit Malfunction
B0655-5A Brake-Light Switch Circuit Incorrect Signal
P0500-71 Wheel Speed Sensor Circuit Range/Performance
P0654-71 Engine Speed Signal Range/Performance
P0550-71 Mileage Circuit Range/Performance
P0460-71 Fuel Level Sensor Circuit Range/Performance
P0115-71 Engine Coolant Temperature Signal Range/Performance
U2139-71 Invalid Signal from CIM (Steering Column Module)
warrington
Business Name
none
vauxhall astra h problem after installing reverse camera
Auto Electrician Forum
steven lightfoot,
steven lightfoot,
