Very old cut out info | Page 2 | on ElectriciansForums
Discuss Very old cut out info in the UK Electrical Forum area at ElectriciansForums.net
kropaske
Feltham
Came across this recently. Looks like 30s, 40s maybe. Does anybody have any info, Bs number, kA values...
[ElectriciansForums.net] Very old cut out info
I read that...I wonder if there is official info about replacing those cut outs.
I think i need to ask customer to approach them directly and get everything in writing. There is too much danger stuff going on there.
I guess it would be different story if this would have been a house - only 1 cut out to be change. Here is 6 in total so obviously shareholders would not be happy...
Please expand on this.......
Ze readings gave me infinity, Zs was good, all bonding in place. So flat was earthed through metal gas pipe. If you look at first photo there is metal conduit which takes tails to the flat but it was not connected to the enclosure therefore no earth to the flat. They did put earth clamp on this conduit and run 16mm earth to the MET inside property but forgot to do it on the other end. All flats are like this...
I did put link to get my Ze...
:eek:Check the MOCOPA guide to see what it thinks about BS951 clamps attached to the incoming cable. As a matter of interest what was your Ze after you interfered err sorry interacted with the DNO equipment?;)
Reply to Very old cut out info in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
