Veto Pro Pac...... yes or no? | Page 2 | on ElectriciansForums
Discuss Veto Pro Pac...... yes or no? in the Electrical Tools and Products area at ElectriciansForums.net
I never get anything for promoting Veto bags but I just love them so much i'm happy to give them some free promotion!
Very surprised at that Jordan... there’s gratitude for you! If they change their mind and send you some freebies you can send the surplus my way ;) Haven’t been able to justify the pice yet.
I’ve just made the decision NOT to go the veto route. Controversial I know...but decided to go with Wera 2Go instead. The thinking behind this is only to carry into the job what you need/ want, and leave the rest in the van. Started buying them, cheapest place seems to be Amazon, followed by eBay. But Screwfix cheapest by far for the big bag.
Although I’m a bit of a tool tart, trying to be realistic and cut down to tools that I actually need, and not just carry for the sake of having a full tool bag. So divided my kit up, less to carry at each time, plus it’s more secure in the van than left on site in another room while you just do that 5 min job in another room etc.
[ElectriciansForums.net] Veto Pro Pac...... yes or no?
I've got the TP5B, still trying to find the right balance;
On handle; Brown blue gy tapes, leather an in pouch.
In belt loop; Klien 935AB4V spirit level
D ring on picture left; Erbauer Impact bit selection box, Klien magnetiser, meter box key
D ring on picture right; leash connection to M12 impact driver
Back row (5 vertical sections); Rolson multibit pistol grip ratchet driver, M3.5 tap, Draper Ergo Expert Needlenose (NN),
Draper Ergo Expert 7-in-1 Pliers, Aldi VDE drivers 2x PH2x100mm, 1x PH1x80mm, Slotted 6.5mm 5.5mm, 4mm,.
Mid row; Aldi auto wire strippers, Martindale VT12 2pole tester
Front row; Marxman, Preciva Bootlaces crimper, LAP clamp meter, Pen flashlight
Left side exterior pockets; 8oz claw hammer, CK VDE 3x0.5mm slotted, CK VDE PH00, brush
Right side exterior pockets; Irwin 7-in-1 but driver, Wickes strike through slotted and PH2 beaters, double ended perm marker, magnetic light on stick, Milwaukke M12 Impact - Chain attached to bag via clip to keep tool secured to bag when not in use
Very front; Stanley Fat,ax 8m tape
Inside pocket (not visible); Kewtech Kewprove3 and lockout kit, CK VD Stubbies PH2 & 4.0SL & MOD2, Hex chuck to 3/8" socket converter (allows use of Irwin sockets in impact driver.
So far has given me everything I've needed at hand.
Reply to Veto Pro Pac...... yes or no? in the Electrical Tools and Products area at ElectriciansForums.net
I also have a few no name cheapy tool bags probably similar to your Aldi/Lidl variety that are set up as a 'grab bag' with the exact tools and...
NHS Forums - Pro Tiling Tools This is the NHS Forums Discussion Thread Check out our friends at NHS Forums for Staff and (separately) Patients...
