hey guys
had to replace the VFD on my lathe. running off 240v single phase to 3 phase to control the motor in delta config.
i wired the new vfd up as per the last one, which is a different brand. hooked up active and neutral, then the ground to the chassis screw, when plugged in instantly trips breaker, take off earth and it doesnt trip, if i test between house earth(while disconnected to vfd) and chassis of vfd i get 110volts, i also get voltage between chassis of vfd and active and nuetral while the vfd is running, i havent used or touched the vfd because i dont trust it being live. wondering if this seems like the vfd is shorting to the body of it?
