wrighty
alright folks,
Im in the process of buying my first house. The house needs some work doing especially a rewire. The home owner is a ive worked on a building site and seen it done before type of bloke. Will upload pics when sale goes through unless they have to get a CU change done, but in words the main switch on an old rewireable fuse box is broke, so hes jammed the Live into the open side of the fuse with i presume just the fuse carrier holding it in looks that way to power all ciruits, was shocked when i saw it, he even told me himself it was illegal. Not to mention highly dangerous as the fuse board is located under stairs which is used as storage aswell.
so anyway back to the reason for my post due to the above problem and me wanting sockets etc where i would like them im going to be rewiring the property. so during the rewire ill also be fitting an intruder alarm and tv points/virgin media. My problem is ive never done any tv points or anything myself before and im a bit lost for where to start. Basically im wanting TV/virgin media in the majority of rooms, now i know i can get a box from virgin for each room but that implies monthly charges, also i dont want to have the same channel on in every room.
So im hoping a few of you that are experienced in this field could help me out. My aim (not sure if its possible) is to run 2/3 boxes with possibly a couple of magic eyes like for sky to be able to change the channel from each room. The virgin coming into the property is located in the living room, Im looking at maybe 1 box in living room, and 1 in main bedroom, (3 bed property) can i distribute the signal from 1 room into a further 2? can i use magic eyes to change channel? and without sounding daft will normal flush coax plates suffice or is there a certain type i need for virgin media?
If above is possible i was thinking of running cables from each box to other bedrooms to give maximum channel options. So if my OH was watching tv downstairs i could watch something different in 1 of the other bedrooms or if she was watching in main bedroom i could watch something different in Other bedrooms as such
long winded i know but any help would be greatly appreciated
Seen as I used to work for ntl: / Virgin media as an installation tech then moved way up to service and network tech... I'd strongly advise you not to use any old cable for this, you need specialised low ohm RG6 or RG59 screened cable, you also can't terminate this to wall plates as this will reduce the dbmv and the spectrum used is 20-800Mhz, and wall plates do not go this far. You can buy the cable from Commscope, Hager sell FSAT plug modules for europlates without any anntenuation, of just get yourself some blank 1G plates, drill some holes and fit F coupler barrels, so you can terminate the cable to the barrel, if you need the pressure fit F Plugs let me know as have a few spare, you would need the compression tool available from mills ltd, same as the cable stripper.
Internally you can do what you like, but you're not allowed technically to add, extend or modify any of virgin's network as if you terminate incorrectly and use the wrong cable etc, you will cause the SNR to increase and noise on the network.
You can get Virgin to come and leave you the cable, you route it all and they will then return and terminate if you are having them in each room.
For the same channel in every room, run Cat 6 cabling, x 2 to each room and then run HDMI over Cat 6 using a HDMI matrix :) meaning you get the same channel in every room. you can then also use a magic eye to change channels if you grab yourself a logitech harmony programmable remote control.
i second what kris says,their installers are rough as..make bt look neat...if you want multi room its flat carpets up,bumpy carpets back down,get the cable and run it yourself..
alright folks,
hello try this item ,
[video=youtube_share;BEHG3f0QI7s]http://youtu.be/BEHG3f0QI7s[/video]
I actually had a qualified electrician cut through my Virgin cables with a hedge trimmer............you just can't get the staff......
Thanks pet ..... I really wanted them all to know that !!! :behead:
Anyway, it should have been run in a Safe Zone ... NOT through the middle of a sodding bush !!!!! :32:
I was never like that! Maybe that's why I got paid the big bucks and progressed onto service tech and then network tech, most installers for virgin are sub contractors. Such as maps, Fujitsu or Kelly's.
As for the cabling in the hedge! That's a sackable offence! Must be buried in flexible conduit or clipped direct to wall etc.
I know !!
I looked and saw the cable was clipped to the wall about a foot off the ground at one end of the bush (hedge really) and saw it at the other end of the bush - again about a foot off the ground & clipped to the wall & assumed - wrongly that it would be either clipped all the way along the wall or protected by conduit. It wasn't. Instead, it rose about 2 feet higher as it passed through the bush which I was cutting down so the blokes who are coming to fit cavity wall insulation could get access to the wall.
Virgin Media sent a woman out yesterday to fix it with a big orange joint box filled with silicone stuff & left it dangling in the bush ...... :32:
I have to say it looks a bit of an eyesore............. the woman who fitted the orange box wasn't even a spark, but a van driver who "does stuff as and when!"............ considering the extortionate prices Virgin charge you would think they would be a bit more professional. Maybe Branson should stick to making small bite pickle.
Yes pet. :yes: :love:
I know !!
Those orange boxes containing sticky stuff are sodding expensive! can't remember its name!!! have a few in the garage kicking around... and they are a temp fix, they will have booked you in for a re pull :)
make sure you kick up a fuss, find the local depot they work out off or let me know and ill find you the contact in there to speak with to get it put right :)
wrighty
leeds
virgin media and tv wiring
FreeSat, Sky, VirginMedia Forum
wrighty,
tidyboiler,
