Discuss Voltage Indicator Fault in the Electrical Tools and Products area at ElectriciansForums.net
Selfmade;800301 ...I didn't get a warranty with this so opened it up to see if I could fix it myself - am I still entitled to a free replacement? It's 10 months old. I did find that the lead insulation was damaged inside the casing (strange?) but wasn't able to fix it. Sam[/QUOTE said:...and my sales receipt was destroyed in a localised bonfire in the filing cabinet!
Hi, I have the same problem. Again, my voltage tester came free with an MFT bought from Test-Meter. It's a HandyMAN TEK900 and looks identical to the one linked to by Derek, except for being red instead of yellow (I think these are all made by Metrel and sold under various brands).
The Auto Test lights up all the lights, but when testing with a known supply only the polarity and single pole phase LEDs light up - not the voltage lights. There is also no indication of continuity when the probes are shorted together.
Sam
10 month send it back
What do you mean you did not get a warranty ? if you bought it online then you will have an online account as proof of purchase or the invoice they emailed you as well . These things dont get stripped down and fixed they get binned and replaced.
Sorry mate nothing is adding up for me here.
Did everyone try replacing the batteries? I've often had weird faults, even on brand new units, which turned out to be a rubbish pre-installed battery (often older stock at a guess).
Just a thought...
Rechargable batteries are great for some things but I wouldn't use them in test equipment due to their voltage being 20% lower than normal batteries.
As Guitarist, that was my thinking as well.
I've had trouble with an old Megger Loop/RCD tester on rechargers. Just flags up noise on the line when doing loops, and basically ends up being a random number generator! (May as well sit in the local cafe and write out the reports! )
Unless the tester has a specific setting for rechargeables, such as the Megger MFT1730
Reply to Voltage Indicator Fault in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
