Went to a job the other day, where the client wanted a light fitting put up instead of the ceiling rose. In conversation they mentioned having problems with their electrics, and had had a new CU fitted. I decide to measure ZS & RCD at the said ceiling rose. However, my tester (Megger1730) aborted both tests due to 'high touch' voltage. Measuring voltage at the rose, 242v with light switched on & 184v with the light switched off. Light is controlled by 2 x two way switches, with a 3c & e at each, and tw & e at the rose itself, so obviously JB somewhere.
One of the switches is a metal plate switch, measuring voltage there (to neutral bar of adjacent CU); 242v on red strapper, 54v & 52v on blue & yellow strappers, and worringly 54v on cpc. Client said they thought they had received a shock from switch, but had dismissed it. Adjacent ceiling rose (on same circuit) & socket outlet, gave suitable ZS/RCD test results. I didn't do any other testing, as I ran out of time. So made light and switches safe and made an appointment to go back and further investigate.
Never come acorss this myself before, but have read of induced voltages. No flourescents or motors etc at the property (TN-S supply). I suspect an incorrectly wired JB, but I can't fathom these voltage readings?
