Voltage Stabiliser | Page 2 | on ElectriciansForums
Discuss Voltage Stabiliser in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Don't know enough on this subject but be careful with the PV, think most voltage stabilisers can't handle pv, check in solar forum for more clarification.
Just using a transformer will be fine.
the voltage will fluctuate +10% -6% here as it does abroad so no problem..
legally through harmonisation rules you shouldn't need to do anything
A transformer will not provide voltage stability. The O/P will vary with the I/P which isn’t what this question is about.
thats why i sugested a ups.
because the grid supply will technically just become the charging circuit and everything runs off the ups battery this problem is negated.
Not strictly true.. Voltage levels vary but the tolerances are the same.
therefore, voltage stabiliser not required, just a transformer
Irrelevant anyway as the kit is rated 230
Not irrelevant, the kit is rated 220 - 230V apparently and out voltage is 240 -250V in reality. But it does occasionally dip lower so a transformer would drop the voltage too low sometimes. If the machine needs a more stable supply than it has at the moment then a transformer won't cure the issue
im sorry but that is incorrect
Which bit is incorrect?
The machine is rated at 220 - 230V
Our mains supply is normally between 240 - 250V bit dips towards 230 occasionally.
A transformer will adjust the voltage proportionally so will not maintain it's output voltage when the input dips.
Reply to Voltage Stabiliser in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
These are questions to complicated for a simple answer It depends on many things Cable size Cable length Load type and current Filtering and...
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
