Voltage still detected after rcd had tripped? why could this be... | Page 4 | on ElectriciansForums
Discuss Voltage still detected after rcd had tripped? why could this be... in the UK Electrical Forum area at ElectriciansForums.net
srl-8
Hi all,
I have install a RCD fused spur on the end of line feed to a bathroom lighting circuit. Thus protecting the bathroom with rcd.
I tested the rcd (manually via the push 'test' button) and it killed the lights and fan as expected.
I used my volt stick to confirm that the cables were dead, but to my surprise , The voltstick was telling me the there was voltage still present. How could this be?
My understanding was that with the RCD tripped, it should kill all power on the load side of the spur, .
Any ideas????
Totally irresponsible. Nobody should ever throw away their wood if its live and in their hands :D
hmm. after GMES has played his 1st round of golf, i think he'll be throwing away his woods and his irons.:ack2:
The reading is coming from the fan motor in the bathroom...
is the fan connected through the shower? could be static caused by the water flow. try turning down the water pressure. :46:
Reply to Voltage still detected after rcd had tripped? why could this be... in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
