Guest viewing limit reached
I am currently using a strip connector to connect my cooker, hob and dishwasher to a radial circuit. This has come loose on a number of occasions and so I am considering replacing this setup with Wago 773-173 connectors. These can only facilitate 3 conductors but I have 4 to deal with . It has been suggested to me to use 9 of these connectors set out in three groups of three each.. The first group of three will be connected to the radial circuit and send wires to the second group of three and the third group of three. The second group will be used to send power the the hob and dishwasher and the third group will send power to the cooker.
Thoughts on this setup would be appreciated.
That's what I said, but some hobs/ovens need a larger supply that 10 amps especially induction hobs unless you have the convenience of a three phase supply.
London
United Kingdom
Retired Electrician
Wago 773 173 advice please
UK
Bill Johnstone,
Mike Johnson,
