Wago connectors, DIN rails, Wiska box | on ElectriciansForums
Discuss Wago connectors, DIN rails, Wiska box in the Electrical Tools and Products area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
Anyone used DIN rails in Wiska combi boxes to hold the Wago push fit block connectors? Any good?
Cheers LankyWill. Know what you mean. Keep it simple. Just looking at options for a lighting and switch line on some outside lights ...plus wanting to have a play with some of the vast array of products at out disposal out there!
OCD and procrastination. I do have a tendency to try and over engineer things. Will have to get over it as time is money although I suppose that's why I'm looking for the best solutions.
Cheers. Will they take an SWA gland and earthing nut?
Not sure if earthing nut would fit or not, although a couple of lock rings and a banjo will, there are knockouts on all sides for 20mm or 25mm. These boxes are a bit bigger than the standard single box size thou ! The holder will hold x4 3 lever wago's.
Reply to Wago connectors, DIN rails, Wiska box in the Electrical Tools and Products area at ElectriciansForums.net
Have you looked at the Wiska Wago relocation product. Different sizes available. Saves having to reinvent the wheel. CLICK ME
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
