Wago Junction boxes not meeting the requirements of BS7671 | on ElectriciansForums
Discuss Wago Junction boxes not meeting the requirements of BS7671 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
chiplard
Just had the latest forum offer regarding the LINE Junction Box.
Why is it stating that it is the only compliant JB?
I use Wago JB and am surprised that they don't meet requirements!!
Line use a heavy cable tie to comply, am surprised that you can't tightly wrap one or two around a Wago (who don't make their own boxes).
I heard that the Wago cable retainer is not up to the latest spec with regard to vibration either and is currently being revised. But the spec allows for clipping the cable direct for support too, so should be an acceptable work around.
But finally, it needs a MF logo on it, which it doesn't have so game over.
An MF indeed.
Crazy.
All JBs are compliant with BS7671, if they meet the requirements of BS EN 60670, which is a generic standard for boxes and enclosures.
To be used as a Mainteance Free connection, the Wagos have to be inside an enclosure that meets the requirements of BS 5733, and is marked with MF.
There's no indication that the Line JB is marked with MF.
The BS numbers quoted in the literature, are in fact BS EN numbers.
BS EN 60998 is a generic standard for connecting devices used in domestic installations.
Such devices include screw terminal blocks, Henly blocks and wagos.
The suffix 2-1 refers to screw type, and the suffix 2-2 refers to screwless (Wagos).
BS 5733 refers to enclosures that have cable grips, will retain the connecting device and require the use of a tool in order to access live parts.
Hager's guide tells it like it is.
As Spin has said, enclosures need to have the MF symbol on them to be deemed to comply. The Ashley ones are the only ones I've seen so far with it.
Except some J501's that I still have in stock, soldering iron and a fine tip shall sort that out!!
It seems that the in LINE people are induldging in a bit of scaremongering.
The information from Hager, posted by Lenny appears to cover everything in an easy to understand format, without the scaremongering.
And the new Wagobox light junction box has holes for a cable tie to 'lock' the lid, to me thats good enough to use. And I think they will have or do have the MF logo.
Some good information here.
To clear up a few issues:
1) only mf boxes need mf logo and to comply with bs 5733. ( so your j501 are ok Mark)
2) bs en 60670 is a manufacturing standard. Bs 7671 is an installation standard. It is therefore possible to comply with one but fail the other. This is where the wagobox comes unstuck. Is the fact that the wagobox lite has a integral locking device an admission by wagobox that the wagobox original fails to meet all requirements of bs7671?
3) wagoboxes do not have mf Mark and they do not meet bs5733
4) the line box does meet bs5733 but line tell me they are waiting for wago to confirm that wago connectors do meet the requirements of bs5733. Once wago confirm line will add mf logo.
I have had a good scan of the BRB and have discovered a regulation that covers all. Possibly!!!!!!!
120.4 New Materials and Inventions
Where the use of a new material or invention leads to departures from the regulations, the resulting degree of safety of the installation shall be not less than obtained by compliance with the regulations. Such use is to be noted on the EIC
Reply to Wago Junction boxes not meeting the requirements of BS7671 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
This thread can now be closed, as I seem to also have space in the box for the first switch. Revised diagram below. Thanks folks.
