Wagos for oven | on ElectriciansForums
Guest viewing is limited
Discuss Wagos for oven in the UK Electrical Forum area at ElectriciansForums.net
Steviecuk
Essex
Hi all. Hope you are well.
So my dad has just bought a new induction oven. He already has an electric oven under it which appears that it is hardwired from 6mm T&E that literally just comes out of the wall 🤦🏻‍♂️
the new induction hob has 5 wires (which obviously has doubled up lives and neutrals) but along with the oven as well it would be much easier in a confined space to connect in a junction box with Wagos.
I was thinking the Wago 41A junction box and the Wago 211 41A 4 or 5 way lever connectors. The box would then be mounted on the wall.
Does this conform to regs a) using Wagos and b) with the built in Wago strain relief clips.
I just know trying to jam 4 wires into a traditional outlet box won't be easy in a tight space.
Look forward to hearing back from you.
if you use the 6mm2 version of the wagos and its in a MF box ,suitably located ,it should be ok.
The only concern is the protective device ,protecting the flex cable,this is no different to a flex outlet
ok so something else has now come up in working this out... the oven is rated at 15a and the hob at 30a. The MCB it's connected to is only 32a. The fuse board has the old Centaur Type 1 M4.5's.
I know the oven won't be at full tilt along with all 5 induction rings on max at the same but will this work with the current setup or keep tripping? If so is it possible to get a newer 40a MCB fitted in its place?
Reply to Wagos for oven in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
