wall light fault | Page 6 | on ElectriciansForums
Discuss wall light fault in the UK Electrical Forum area at ElectriciansForums.net
A
amckay
My neighbour asked me to put some fancy switch plates up after he decorated. So I'm screwing the plate into the back box and Bang! I mustn't of tightened a connection properly (prob should have turned circuit off too lol) :-( so I make everything ok and re energise circuit but lights for that switch won't illuminate. Change of bulbs reveals its still not working. I've used a non contact voltage detector to check there is power to the lamps and have checked continuity using a fluke t90 and some old offcut to make up the distance and continuity is fine on both L+N. I can't do IR as my tester has been sent away for calibration with screwfix.
I've never come across this before and so far I'm stumped. Any ideas where the fault lies?
Well the earth cont is ok, he had pir and after looking at certs it seems ok. I'll know better when I test it myself tho.
well after reading the shambles that have been your posts fella you have convinced me of several things:
1) you aint an electrician...
2) you aint competent...
3) yet again we have someone turning up without any test gear..(anyone remember the fella in glasgow?)...
4) something as basic as this has baffled you...and the wrong use of terminology says `DIYer` to me...
do you fail to read OPs? Had you read it properly you wouldn't have commented.
Prove I am not an electrician and prove I am not competent.
My certs speak for themselves....
A genuine question gets asked and majority of you all jump on the band wagon and start having a pop. This is a forum to help each other out when needed. If you jokers had read my OP PROPERLY then half of these smart ar$e "answers" arnt needed. More to the point I doubt you would all say stuff like that when stood toe to toe with me.
If you have no constructive crittisism to give, keep your trap shut.
...my tester has been sent away for calibration with screwfix.
Hi, do you have a link to this service? I didn't know that they did this.
I dont have a link but my local branch has several 'open days' throughout the year for calibration. I can only assume each branch is different as I know it isn't screwfix who calibrate them its an external firm.
Wrong i would say it toe to toe.... plus i asked how you left the customer when you left??
No lights ???
You have had every inch of advice possible so why you crying??
I can understand that, you are correct, however you lost me when you started talking about bulbs and voltsticks, doesn't go down well here, check out the forum name. Anyhow back to the OP, how did it end up? did you manage to get the power back on?
Presumably the circuit worked fine before you screwed the switch back (you said that you had screwed it back after functional testing)
Then the fault must either be...
In the switch - if you had pinched the switch return with the platescrew then the switch would have carried all the fault current (apparent voltage at the light does not prove the switch is ok)
In the circuit somewhere (not the neutral) - fault current through a dodgy connection somewhere may have separated a termination.
I think the 'abuse' you have received has been because:
You worked on the switch live
You mentioned not having your test gear (often used excuse on here)
Your use of terminology
You asked on a Friday night lol
:smilielol5: .
Dillb as I have read a lot of your comments which all seem to be snide, and given the time each of my comments have been posted, it is apparent that you spend all/most your time on here.
To everyone else, I didn't actually fit the switch plate (2G2W) I was called coz he wired it wrong.
All lights in house are fully working.
Thanks hawkmoon, much appreciated.
it that rite pal?
but your competency dont pal.....
otherwise one of the first things you would have checked after a fault would have been the switch..
but then again how could you have tested through it for continuity when YOU DIDN`T HAVE ANY TEST GEAR ON SITE.....lol
- - - Updated - - -
ey up glenn. just got up?
no....
been out..then came back....
Reply to wall light fault in the UK Electrical Forum area at ElectriciansForums.net
Very technical :D
Better off with the click prw213 as it has twin screw termination.
