wall light fault | Page 5 | on ElectriciansForums
Discuss wall light fault in the UK Electrical Forum area at ElectriciansForums.net
A
amckay
My neighbour asked me to put some fancy switch plates up after he decorated. So I'm screwing the plate into the back box and Bang! I mustn't of tightened a connection properly (prob should have turned circuit off too lol) :-( so I make everything ok and re energise circuit but lights for that switch won't illuminate. Change of bulbs reveals its still not working. I've used a non contact voltage detector to check there is power to the lamps and have checked continuity using a fluke t90 and some old offcut to make up the distance and continuity is fine on both L+N. I can't do IR as my tester has been sent away for calibration with screwfix.
I've never come across this before and so far I'm stumped. Any ideas where the fault lies?
I did see a house in Belfast once with fused neutrals... owner called the place I used to work say he had a prob in that his lights fused and did not come back on after rewiring the fuse... took us a while to find it it but there was a box with all the neutrals coming back and fuses on each of them
yep...
Cast service heads often have fused neutrals as well....i always report `em wherever i finds `em...
RIGHT you lot as your not being very help full to the OP I'm going to help.
Get a plumber in I think it is something to do with the thing in the wot sit that has not been put in the gubings and then touch the other u bit that is part of the thing that has got nothin to do with wot we are talking about, Friday ISThe best night of week
Are you drunk mate?
will do, thanks for that tip all I've got to do now is find a shop that is open, we do have a small carton of red wine in cupboard that wife uses in gravy will that do? or would it be best if I just had anther JD, Got a testing job to do on monday and have to take my tester to screwfix in morning to get it calibrated would like to thank OP for telling us that they do that sort of thing do you think i will be able to get a new bulb (not lamp) for my heavy duty mains tester (neon thing that you test with to make it all safe be before you touch the black/blue or the one that some times has yellow and green on it)
Reply to wall light fault in the UK Electrical Forum area at ElectriciansForums.net
Very technical :D
Better off with the click prw213 as it has twin screw termination.
