Wall socket
Is it ok to spike a socket across an inner wall
Have wired in a few sockets and one is above a cross beam in an inner wall that i wanted to drop down but hole in beam only enough for one twin and earth
Cant get access to open or drill hole as its behind splash-back
But across from where i want socket in other side of wall in other room is socket (single wired end of ring?)
So can spike from it but would mean very short twin and earth (6ins maybe) would this shortness cause a problem
Easy, in the fireplace at the officers mess in the army barracks needed to be outside the Nuclear power stations to protect the installation from wind farm invaders.
You can tell you've never worked at a nuke. They use Civil Nuclear Constabulary not army ?
they're not much use. they let me in. Wylffa for about 4 weeks maintenance work. then they wondered why fish were dying.
I agree, to let you in must be bad ? On the other hand they let me in which is totally understandable ?
You are showing your age. I've worked at Littlebrook too. A lot later in it's life though, almost at the end.
According the the wiki of pedia construction started in 1976 and first unit commissioned in 1981. I would have 19 at commissioning. I wasn't there though, I was working in a totally different industry back then.
