water pump pliers | Page 2 | on ElectriciansForums
Discuss water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Use whatever you wish to TBH, but if you try to present a cable gland that is chewed up through someone using grips to tighten it on a petrochem or offshore job, then I am afraid it will get refused and some poor bugger then has to go to the trouble of changing it out. .
Hence the reason to use proper spanners if at all possible.
Once did get a set of 85mm spanners sent up by the company I was with at the time for some 4c 240mm cables. Bloody spanners weighed a ton.
Reply to water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Some year back there was a case of a young girl killed by being sucked down to the bottom of a pool when being emptied through the power drain...
A problem putting multiple cores into a ferrule is when you need to do testing or fault finding. You can't just drop the ends out of the terminal...
