L
Les M
Hi all , 1st post & its a call for help! Posted this on the TVR forun & someone advised me to join & post here?
Have this TVR Cerbera now for around 9mths, its a 4.5 98 & all has been going well until yesterday.
My own fault , I decided to clean the boot out, I vacuumed it & then I started on the top shelf where all the Black boxes are. I moved each one, the one with all the connectors in I managed to snap a wire off, I found out it was an earth & just fixed it back in by refitting a new small spade terminal into the block, all good it works fine.
Now there is a whole list of things that do not work at all? Its a long list so please bear with me
This is what I have found out that is NOT working.
Buttons-lights for the air con & rear window,Interior fans, Wipers & washer, Main beams,Rev counter, Ign/batt light, Oil light, indicator lights (inside & out) ?
Here is the bits that are working.
Rear Lights ,Dipped Beam, Fog, Reverse & Brake, F/Side lights,Number plate light,Hazzard lights,Instrument Lights, Radio, Windows/Doors & Boot, Starter, Horn, Interior Lights, Cigarette Lighter.
I have read all the google searchs today & can't find any thing on the TVR forums . So I posted it here & on there but they advised me to come here.
I have checked the fuses and they seem
Put the fan heater in there from 4pmm until 7pm, Thought I would drive it around the block.
Dipped lights on, first thing I noticed was the battery light is on when engine running, can't see that in the daytime, then as I am driving along the wipers moved to just in the line of vision & stopped, then i heard a chirping for a split second & realised that the left hand indicator was flickering on the same time as the main beam light?
Oh & the remote will not lock the car now.
What now ?
OK,thanks
What now ?
OK,thanks
