Wet UFH Wiring centre | Page 2 | on ElectriciansForums
Discuss Wet UFH Wiring centre in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Right, I see.
Well, the house is in bits at the moment, so we're good for fitting back boxes :]
Thank you!
IIRC, which is far from guaranteed these days, I fitted some 'stats similar to these a few years back. In spite of having terminals for an external thermistor, they were actually fitted with internal sensors. The terminals were fitted for a different version of the 'stat which did need an external probe.
As for connections, connect N, L and L1 on the 'stats to the corresponding terminals in the control box. I expect the N1 terminals on the 'stats are internally connected to the N terminals (check with an ohmmeter) are will be unused.
Reply to Wet UFH Wiring centre in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
3 core wouldn't, but 3 core and earth should I think. The live from the UH4 could feed both the brown and grey of the valve.
That's brilliant Dave, thanks again. I had to raid my sons felt tips and pencils for any colours available! Apologies for the strange and...
4K
