I'm looking to remove the shaver socket in our bathroom because it's never been used, but apparently this might be "notifiable" or "certifiable" under updated regs as it's "altering" a circuit in the bathroom.
A google led me to Part P but this doesn't apply in Scotland. So...searching and trying to navigate the Scottish building regs is a total mess, going round in circles. It's like someone has taken Part P and re-written it into 80 pages. I'm reading stuff about competent person is no longer applicable and now has to be done by a "qualified" person but they don't specify what qualified actually means. I've been out of the industry for about 30 years but I have a degree is in EEE. I'm sure that I'm competent enough to remove the socket and make it safe - but am I qualified?
Surely I don't need to pay a spark to do this and certify it? Can anyone clarify?
If it was faulty, you could replace it under repair and maintenance without a certificate…. So disconnecting it completely shouldn’t need it.
There are many DIY projects going on across the country where a certificate is never going to be produced for the work done….. and in your case, how is anybody ever going to know.
If it’s a newish house, it could simply be fed from the nearest switch… just disconnect the live and neutral from there.
If you feel your compedent then just remove it.just be carefull as it will most probably be part of lighting circuit ie feed in feed out or if your lucky it might be fed direct from light switch.if there is 2 cables you will have the problem of having to join them unless you can pull them up into loft (not sure of house layout) if your planning on covering the whole then the cables wouldn't be accessible. The only way round that is to use a maintenance free junction box ,but it's not ideal hiding cables behind walls
Yeah, I'm fairly competent/confident. When I started, I had to work alongside the sparks installing distribution boards etc then I got stuck behind a desk to be an engineer. Hated it but the skills stayed with me.
Everything is currently back to studs as part of the renovation so I know where everything is wired and I'll take care of that no probs. It's the notification stuff - don't want to say too much on here but I don't have the luxury of doing it and hoping no one knows.
Frustrating that because I don't have a certification, I have to get a spark in, and where I am, I'm looking at 8-10 weeks. Too small a job.
Can't say too much on here but, its a renovation and unfortunately, it will be known. Bummer.
If you havnt applied for a building warrant then from what I gather the scottish bs only reccomend electrical works in homes etc are done by a sparky who is part of a government scheme.total boll£££s .it discrimination forcing experienced electricians to pay 1200 a year just to have a sticker on there van.thats what I'm being charged and to be honest it ain't worth it .
It's insurance related - no warrant. It's BS as you say. Spoke to the local council and what I'm doing would be classed as "altering a circuit". My experience/expertise doesn't matter, it has to be carried out by registered electrician - i.e. someone with a sticker on their van as you say.
Scotland still comes under the UK Government and its legislation, the main point is are the recommendations to only use a registered electrician mandatory or a recommendation? Then look at your insurance to also make the same distinction. Also look to see what the terms and conditions are to apply for the Warrant and what it covers, again look at what the warrant issuing body consider to be a Registered Electrician, registered with whom, the UK competency register may be acceptable.
Reading this Forum is becoming more and more difficult every time I access it, the transparent headings get in the way and make it almost impossible to read the threads, Dan are you listening.
Mike;
Scroll down to the bottom of page and click at the paintbrush icon….”EF25 Blue and White”
Change it to “New 2025”
Will get rid of the transparencies
I just refresh the page.if there's a warrent involved the local council are looking for you to be a member of bsd ,Building standards division and a certifier of construction.it states it in some of there drawings but it's in the legend part where everything Is probably a generic print off.theres lots of stuff on the legend on some drawings that don't even apply to the actual plans.ventilation is a big thing ,especially in a warrent ,mechanical ventilation in office rooms say ,leaving an 8 to 10mm gap under doors and circulation spaces having adequate natural ventilation. More so in commercial warrents
I'm not sure they can demand the electrician should be part of a scheme ,if the electrician was a registered company with all there tickets ,training up to date and had completed say a Scottish building standard course which can be done on line I think there making a rod for there own back .all councils seem to be trying there hardest to destroy the high street.lots of shops lying empty due to the fact potential tenants want to do some alterations ie simply building a partition and in steps the council and architect adding thousands of extra pounds on to what is a simple conversion.my mate is doing a shop in montrose where the council have stipulated that the outside sign must be hand painted or stenciled in keeping with the character of the high street when the Turkish take away next door has a neon sign .
Aberdeenshire
What am I allowed to do in Scotland?
RuraidhBoy,
Mike Johnson,
