Guest viewing is limited
Recently I got one of these to try and deal with the problems of (re)threading holes that are so close to something you can't get a full turn on a normal tap wrench so are faced with the tedium of removing and part-truning and replacing it several timers per turn:
However, not actually used it in anger yet.
It's not using it , it's knowing you can if you need it, ;)
Says every tool-tart!
Realistically I should have tried to get it some months back, but I can see a couple of jobs that might well need it, or perhaps the bigger bothers (they also do 4.8-8mm and 8-12mm jaw size, but not caliper'd my taps to see what that translates in to for actual thread sizes).
My problem is as I get older my drill bits, reamers and the like seem to put themselves away and don't tell where they have put them
Yes, I know the feeling as I have not got enough space to properly organise things :(
Still, most of the more commonly used stuff is accessible!
What's the 8" cable shears like in the hand ? Is it too big?
CK? Some of the guys I work with prefer the 6" version, but most use 8". I've been using the 9" and find them great - lifted by accident one day and quickly got used to them.
Cheers don't suppose there's much advantage to knipex over CK
Was looking at the bahco but I dunno about the quality
Never used Knipex shears, but can't fault those made by CK - other than nipping a finger between the stops, once in a while.
Have Bacho 6" shears, but not used them - some guys swear by them, but they seem very small. Bahco quality seems to be less consistent than it once was and I think this is down to additional manufacturing locations. Made in Sweden is still generally excellent, but all bets are off for tools made elsewhere.
Finally got these as well for the impact driver , seems very cheap dunno is there diy versions of these, 2 months delay on them
As an Amazon Associate we earn from qualifying purchases.
Great bits. Not good for leaving a neat hole though
Norwich
Trainee Electrician
what are some tools that were worth the price tag?
Electrical Tools and Products
mrsparky,
Zimmerin,
