what are? | Page 2 | on ElectriciansForums
Discuss what are? in the UK Electrical Forum area at ElectriciansForums.net
Surely if you had done the job correctly and done a design for the circuit(s) like you should have then you would not be asking this question as you already know it.
Oh dear! No design, just quessed at the cable sizes etc
Have a 2.5 t&e ring and a 4.0 t&e ring that needs testing and want to know what my maximum readings will be?
Nice one. But don't have osg or regs book not to worry just thought someone could give me a rough idea.
Mate sorry to say there is no rough idea from the amount of info you have given us.
If you don't have any of the books to hand (which you should have if you are testing and inspecting) then it can be worked out by calculation in a lot of cases.
no osg???? then the answer must be in the beano. seriously, hbow the hell do you expect to install circuits safely without ther relevant information. chancer!!!
Reply to what are? in the UK Electrical Forum area at ElectriciansForums.net
Because of the addition of separate columns for RCD type etc. I use Easycert software which gives the option of fitting it all onto one page.
loz2754
L
Good thinking - the other side of that is my garage and also where the gas comes in so probably quite a tidy solution if it comes to it!
