What can i certificate with Nic Eic domestic installer scheme? | on ElectriciansForums
Discuss What can i certificate with Nic Eic domestic installer scheme? in the Domestic Electrician Forum area at ElectriciansForums.net
E
energizedelec
I am a member of the Nic Eic domestic installer scheme and always work in peoples houses but have been asked to do some work in a village hall. Could i undertake this work as part of the domestic installer scheme?
thanks chris
if you are competent to do the work, you don't need to be niceic. part p does not apply. also, you can self certify your work, as long as the village hall committee or whatever do not stipulate niceic approved contractor.
Reply to What can i certificate with Nic Eic domestic installer scheme? in the Domestic Electrician Forum area at ElectriciansForums.net
So, I’m more aiming for the domestic setting myself and I don’t plan on EICR straight away. I am almost certainly not aiming for the industrial...
That's really helpful. Thank you so much, I will take a look.
