C
crabapple
what cert is required for putting an dp main isolator between cutout and cu???
thanks in advance
thanks in advance
Discuss what cert is required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
are you doing a cu change?
Eh ? :-/
My thinking was if a CU change it could be covered on that...... thats all. Trying to save the planet and use less paper!
Reply to what cert is required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
