What code 100ma rcd | on ElectriciansForums
Discuss What code 100ma rcd in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Gunnspark
Hi I'm doing a pir on three bed house. It has 100ma rcd main switch. Would this be code 3 (improvement recommended) or code 2 (unaccepable)?
no code. if there's no 30mA RCDs for sockets, bathroom circuits, cables < 50mm deep in walls, then that's a code C3.
so all you do is code C3 anything that is not to 17th. any potentialo dangers, then code C2.
nope. probably been like that for years and all inhabitants are still alive.just a C3, IMO.
so we have 30ma protection to portable equipment circuits? okay no code for the 100 ma IMO, and no supplementry bonding at all? a code 2 for me regardless of any regs, I like to make my own up called good practice, like fans and showers without local isolation, again a code 2 for me :icon10: maybe a 3 for others.
...... I like to make my own up called good practice, like fans and showers without local isolation, again a code 2 for me :icon10: maybe a 3 for others.
so you give a C2 for no fan isolator even though bs7671 doesnt ask for it ?
pfft , amateur.
Reply to What code 100ma rcd in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
