Discuss What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I see no connector block, a crimp maybeA connector block has been used to extend a 10mm water bond, what code would you recommend?
Good spoti'd be more concerned about that floating open end red insulated conductor and that ropey looking blue crimp connector.
Oh yes Specsavers indeed Tel, my mind was fixed on that crimp, tunnel vision at it's best sorry OP ignore my post #4.behind the blue crimp, pete. (specsavers?)
I would use a screw driver.Hate unfixed block connectors proper unskilled work and those who approve how do you suggest anyone can check terminal tightness in this instance.
Reply to What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
