What code? bonding conductor | Page 2 | on ElectriciansForums
Discuss What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Back of the board has been knocked out leaving internal conductors exposed to a combustible surface.
I haven't seen someone cut the back of a board out before. I'd have thought it would've compromised the manufacturer's design in several non recoverable ways. Stuffed it, in short.
I must say I see many CUs around here installed on wooden battens and all cables coming in through the rear knockout. Usually Wylex or Crabtree. Seems to have been the standard way of doing it for a long time.
Indeed. It's particularly advantageous where you need to add cables later. If access is tight, making a new hole in the side/top/bottom of a CU can be a right pain.
Bit confused where does mounting it on battens come into it. The board in the picture clearly has the back knocked out, is mounted flat leaving conductors exposed to a combustible surface.
Reply to What code? bonding conductor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Personally, I would just put them in the observations, the inspection schedule is not exhaustive.
Surely one of the most important parts of supplementary bonding is to bond the radiator and hot tap/pipe to the cold one. Both the hot tap and...
