What CSA would you say? | Page 2 | on ElectriciansForums
Discuss What CSA would you say? in the Australia area at ElectriciansForums.net
Amp David
Mentor
Glossop
Looking at this picture, what size CSA would you the black bit of cable is?
For reference working fronm left to right we have
2.5mm, 4.0mm, ?mm, 6mm
[ElectriciansForums.net] What CSA would you say?
Ahhh...now I remember. 7029.
It is all stranded, including the cpc.
It had a shiney outer insulation compared with todays T&E.
Mostly, when ive been involved with it, during rewires its been ripped out because its part of a rubber installation (due to additions and alterations), it was always replaced with modern solid core PVC. I think it has a tinned ingredient to the copper?
Im sure the stuff is probably fine.
Edit.....infact I think the stranded cpc on 7029 might be a larger csa than the solid 1.5mm found in 2.5 T&E?
Take it the 029 is 0.029 inch diameter of the strand?
nope, strangely, the bigger the number, e.g. 029, the thinner the wire. wikipeda has a metric equivalent chart. google standard wire gauge.
yes, the rubber insulated older stranded cables have mostly all now perished, the later pvc are uaually still as good as new. and you are correct. the cpc was usually greater cross section than now
I come across 7029 all the time round here on domestics. As SMB said itr's usually tinned. It does usually stand up well in IR tests though I find it an absolute pig to work with.
what's a pig. i find it easy. it's more pliable and doesn't set like concrete in the cold.as does the solid crap we have to use now.
Really? I find it gets really rigid, maybe where it's 'set' over time. Also it's a pain to strip, and if you're replacing an accessory with, say, a spur on it, it's really hard to get it all into one modern accessory. The main thing is, though, I don't like working with it because invariably whoever installed it twisted it all together to within an inch of it's life! Once untwisted it's IMPOSSIBLE to get all the strands straight enough to terminate properly.
Had a few instances when I was a "Boy" near a large park where there was a sheltered housing complex wired with old shiney PVC which had attractive something that the Squirells enjoyed much to the delight of my gaffer finding them welded to cables
coming from a youngish spark now, but i was at a house the other day where i was changing a few old sockets to new ones, and i was pretty positive that the ring final was in 4.0mm guess this explains it.
cheers guys!!!
danny
Reply to What CSA would you say? in the Australia area at ElectriciansForums.net
L
Trying to source an obscure size octagonal tile I hope you can help we are trying to source (for a match) some 300mm by 300mm matte white taco...
Lisa Rogers
L
