What do you all use | Page 3 | on ElectriciansForums
Discuss What do you all use in the UK Electrical Forum area at ElectriciansForums.net
R
Rauer
What do you use for your Certs?
Pen & paper
Or software if its a software which one and is it expensive/worth the money? Surely there's a cheaper alternative to easycert?
I am after one that preferably does form filling for cheaper than the above!!!
Easy cert always updated quickley and has WEB back up so im not going to loose them if my PC crashes if there is a problem tech support is replied normally within the hour ,all drop down menus so really good updated regularly, has all the Certs for me including EICRs Fire alarms etc
A plus for me
the company i work for use AMTEK its great but I have used a excel one that was different and had a couple of things Amtek didnt as Im sure easy cert ect have its realy down to personal preferance and what you require
doing hotels where 20-500 rooms have the same dbs Amtek "copy db" is fantastic saves inputing loads of the same info just fill in test results and alted as required for disabled rooms They now have the "up Down" sorted on P2 great for likes of me who take notes then sort out page 2 listings to an order with dbs and advisorys,notes at end You can also move dbs around The schematic diagram done fofr dbs is another good thing
Reply to What do you all use in the UK Electrical Forum area at ElectriciansForums.net
P
CRM SOFTWARE - your opinions on the best few brands please Hi Everyone, I currently use E-Works CRM software and feels it does have good...
plumb_know
P
Most manufacturers recommend them to be fitted. We are required to take that into account. If they had been fitted clearly it would have been...
