what drill? | on ElectriciansForums
Discuss what drill? in the Electrical Course Trainees Only area at ElectriciansForums.net
Mid Suffolk - Framlingham
thinking of finally getting a new drill on payday since i my sister and her partner have taken their spare titan 10.8v back.
i have several projects to do around my smallholding which require drill into wood and screw driving. also, since i am starting college in September and will be taking my job search up a gear, i would like a drill that will be up for the task.
i love the 10.8v stuff, it does exactly what i need at home and the contractors at work cant rate their makita and bosch 10.8v gear enough. they use it more than their 18v stuff.
i have ÂŁ100 to spend.
my question is .... what do you guys use day to day at work and do you think 10.8v gear will be up for the job if and when i get a job in the industry ....
Someone on the forum kindly recommended me the makita 458 I got it with two 3ah batts and a charger for ÂŁ199.
It's been great so far going through walls and joists with ease even with cheap bits.
I was going to get that makita 453 they always have in Screwfix at ÂŁ149 someone said it was a toy.
I'm not sure if that's true :)
We have both and the 453 is a toy compared to the 458.
Good choice.
Only problem with that is you can't drill a hole in brick or concrete with a 10.8 so your stuck if you need to drill a hole for a plug. Like I say I use mine everyday but it's more like a screw gun for me
the 458 is a bit out of my price range ...... is the 453 worth the ÂŁ120?
im now tempted to get a 10.8v combi drill for now and invest in a decent 18v when i land a job.
Personally I don't think so.
That would be the way to go. Not worth buying something you could potentially be provided with (job dependant!).
Reply to what drill? in the Electrical Course Trainees Only area at ElectriciansForums.net
