what impact driver do you guys use? | on ElectriciansForums
Discuss what impact driver do you guys use? in the Electrical Tools and Products area at ElectriciansForums.net
USA
looking to buy an impact driver, used a workmates 10.8 drill/driver makita set and im impressed
what do you guys use?
tempted to get the milwauke myself
The Bosch 10.8 is a brilliant driver with a lot more torque than you'd think, it's also a really good size to keep in your tote so you've got it handy when you need it
Durofix 18v :D never had used one before I seen them at the show a few years back and its still going strong and the led torch is good for about 6 hours too :D bonus
I use this one
  • [ElectriciansForums.net] what impact driver do you guys use?
Never realy had the need for an impact driver as an electrician.
Used them when doing vehicle repair and maintenance, and when working as a maintence engineer in a factory.
The type I have though, is one you thump with a hammer and is made by SnapOn.
Square shaped with rounded corners and I believe 32mm across, so a spanner can be used for added torque.
Reply to what impact driver do you guys use? in the Electrical Tools and Products area at ElectriciansForums.net
Definitely find the mechanical clutch is better on the new one.
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
