R
rattlehead85
Milwaukee fuel impact driver is the ----!!
Discuss what impact driver do you guys use? in the Electrical Tools and Products area at ElectriciansForums.net
changed my mind and thinking of getting makita lxt 202
what do you guys think?
(18v impact+drill combi set)
£274 here for the combi from that kit
BHP451RFE 18v LXT Combi Drill 3 Speed Makita
anyone used this seller? thinking i would rather pay more and pick up from toolstation/screwfix. that way i can take it back if there is a problem
(Not actual size)
i wouldn't use an impact driver to drill holes in trunking. all you'll do is smash the cutter or pilot bit and buckle the trunking
I have a 12V Black and Decker Professional Drill (forerunner to Elu and DeWalt), with two hammer settings, that I purchased in 1991.
I purchased the Drill because it used the same batteries as a Black and Decker cordless hedge trimmer.
The drill (and hedge trimmer) found much use when I purchased a house in 1994, however since leaving my then wife and house has found little use since.
I mostly use it to remove rust on motorcycle frames (where an angle driver will not fit), on restoration projects.
The only time I use a drill as an electrician, is to make holes in masonary, etc.
For such, I use a 24V Bosch.
No, I conduct very little domestic work.
Obviously I do some domestic work, but the majority of my work has has not been domestic, far from it.
Yep, trunking, tray, ladder, conduit, basket etc.
BMS, HVAC, door access, alarms, PA systems, data, power, lighting, even some CCTV.
Maintenance, refurbishment, new installation even rail work (signaling, earthing, power and lighting).
Most notable projects I've worked on are: O2, Emirates Stadium, St Pancras, Channel tunnel, Olympic Park Victoria Underground station.
Worked on a number of hospitals, colleges, schools, hotels, office blocks, animal laboratories, retail.
In retail, I've worked on LloydsTSB banks, Selfridges, John Lewis, the ex Alders in Oxford St. (now Primark), Westfield Stratford, The Stables Camden Market.
Worked in food manufacturing, maintenance and refurbishment.
Even worked in a sewage plant.
Whats the best voltage to get for commercial electrician? Is there much difference between the 10.8V and the 18V makita range? Would I be missing out if I got the 10.8V
Reply to what impact driver do you guys use? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
