What is the name of the fault when main bonding high resistance? | Page 2 | on ElectriciansForums
Discuss What is the name of the fault when main bonding high resistance? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sounds like a high resistance fault( HRF) on a cable that should have a low resistance, you could refer to it as a or HRR (high resistance reading) or a HRROAC ( high resistance reading on a cable) or a TAHRROTCWSIPOTSFT (that's a high resistance reading on that cable what should I put on the sheet for that) lol
Brillaint!
blind leading the blind
544.1 - any other questions ?
I don't question his qualifications (might be cowboy) - just try to help without sarcasm. Is like speed camera - if you slow down and are not flashed, then it fulfilled its role.
In the past I had guys learning from me in work and become contract maganers afterwords - still yet being judged. You have no clue what is Kirhoffs laws? Or for example where the factors in BS7671 have come from? Or let me say that Impedance is not resistance measured under AC conditions but is summary of two different reistances Z=R+X resistance and reactance, which varies from resistor, trough condensor and inductor in electrical circuit. Also that in AC we use not full curve of voltage under frequency of Hertz. Have you ever heard of these ever? Or just passed 3 years school, then 2382, NICEIC registartion - and playing smart? For you - SPD was introduced in UK in 2011 - in Eastern Europe they are vastly used since '90. Every building and installation has to have surge protective installation since I remember and I graduate in 1989.
So I tell you this - go and learn ring final better.
I don't question his qualifications (might be cowboy) - just try to help without sarcasm. In the past I had guys learning side by side in work and become contratc maganers - still yet being judged. For what that you have no freaking clue what is Ohms or Kirhoffs laws? have you heard of these ever?
You told the guy it was a C1 code this part I stated blind leading the blind
because it is C1 - no continuity on MPBC. The resistance over 2 ohms on MPBC the cable is f ... d and is not able to accomodate fault current flow into safety
- - - Updated - - -
Reply to What is the name of the fault when main bonding high resistance? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If you can see a piece of plastic entering from the ground then (as cliff said), it does not need main bonding. I think (not sure) this is reg...
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
