It's been almost 4 years since the council updated all the electrics in the house, at the time they moved the fuse box to the back wall rather than the side wall. Today curiosity got the better of me and I'm just wondering what this is, as it doesn't look normal. At the time a council inspector looked everything over and said it was OK.
Basically wires coming through the wall where the fusebox used to be, going into this little bar with screw things on it, they just plastered over all the wires. From the little bar are more wires going into the fusebox.
What is this, and is it normal/safe?
As soon as i read the first line "It's been almost 4 years since the council updated all the electrics in the house"
i knew it would be more likely than not that the standard or workmanship would be poor.
Have seen some right awful council rewires over the years, the worst was over in wales, all run in plastic trunking, wall mounted, the walls were that damp we had to screw it all to walls as the stuff kept falling off!
With these types of jobs its a race to the bottom with a focus on minimum of cost.
Yes that's an earth terminal. It's normal to have such a terminal, but not normal for the terminal to be exposed. The earth circuit should be treated and protected as if it were live, as that's literally what it's there for. If there is a fault, to carry the live current back to the earth... So if you get a fault, that becomes live and it's exposed...
I'm not a qualified spark but I'd avoid fiddling with/licking the terminal.
Reliance on stick on trunking :eek: :coldsweat:
Can't rely on the sticky stuff best to always drill trunking to the wall :fist:
There again,maybe I drill it only because I'm used to the damp walls in these parts:)
Looks like your Main Earthing Terminal. Messy job but not unsafe. They’re usually mounted near the meter
Out of interest, how is that not potentially dangerous if there were a fault that led to the earth terminal carrying current? It is surely only there as it 'may' one day need to carry current.
Ignoring the RCD protection that must be present on the new box anyway, as that can fail and the earth terminal could carry current undetected for a length of time in some situations.
Just curious as to how that is safe?
While it's connected its safe . (If it needed to carry current)
(any attempts to pretty it up , in an unskilled/untested way....
could make -- all Protective Earths in the building --unsafe)
Thanks but I'm still confused about this. I totally understand that having it visible/accessible means it's safe as far as inspection goes... And I understand that a bodge job to hide it could damage earth continuity and leave a greater potential danger.
But surely it is designed to carry current in certain situations, so it's not safe to be exposed. How can it be?
Why can't it just be mounted in the CU as in fairly typical these days. Surely that is safe in both regards?
You used the word "potential" in your post
Food for thought :)If someone were to touch the earth bar, what else could they touch that can cause a potential difference to expose them to harm
England
What is this and is it normal? Council electrics
RyanA,
Pete E,
