It's been almost 4 years since the council updated all the electrics in the house, at the time they moved the fuse box to the back wall rather than the side wall. Today curiosity got the better of me and I'm just wondering what this is, as it doesn't look normal. At the time a council inspector looked everything over and said it was OK.
Basically wires coming through the wall where the fusebox used to be, going into this little bar with screw things on it, they just plastered over all the wires. From the little bar are more wires going into the fusebox.
What is this, and is it normal/safe?
As soon as i read the first line "It's been almost 4 years since the council updated all the electrics in the house"
i knew it would be more likely than not that the standard or workmanship would be poor.
Have seen some right awful council rewires over the years, the worst was over in wales, all run in plastic trunking, wall mounted, the walls were that damp we had to screw it all to walls as the stuff kept falling off!
With these types of jobs its a race to the bottom with a focus on minimum of cost.
Yes that's an earth terminal. It's normal to have such a terminal, but not normal for the terminal to be exposed. The earth circuit should be treated and protected as if it were live, as that's literally what it's there for. If there is a fault, to carry the live current back to the earth... So if you get a fault, that becomes live and it's exposed...
I'm not a qualified spark but I'd avoid fiddling with/licking the terminal.
Reliance on stick on trunking :eek: :coldsweat:
Can't rely on the sticky stuff best to always drill trunking to the wall :fist:
There again,maybe I drill it only because I'm used to the damp walls in these parts:)
Looks like your Main Earthing Terminal. Messy job but not unsafe. They’re usually mounted near the meter
Out of interest, how is that not potentially dangerous if there were a fault that led to the earth terminal carrying current? It is surely only there as it 'may' one day need to carry current.
Ignoring the RCD protection that must be present on the new box anyway, as that can fail and the earth terminal could carry current undetected for a length of time in some situations.
Just curious as to how that is safe?
While it's connected its safe . (If it needed to carry current)
(any attempts to pretty it up , in an unskilled/untested way....
could make -- all Protective Earths in the building --unsafe)
Thanks but I'm still confused about this. I totally understand that having it visible/accessible means it's safe as far as inspection goes... And I understand that a bodge job to hide it could damage earth continuity and leave a greater potential danger.
But surely it is designed to carry current in certain situations, so it's not safe to be exposed. How can it be?
Why can't it just be mounted in the CU as in fairly typical these days. Surely that is safe in both regards?
You used the word "potential" in your post
Food for thought :)If someone were to touch the earth bar, what else could they touch that can cause a potential difference to expose them to harm
The outer metal case of anything else plugged in and earthed - I did think about that :)
But it's still going to want to take the most direct route to earth, which is via that earth terminal. So I'd rather be touching outer case of anything else plugged in and earthed than that terminal the earth circuit became live.
They are there as a direct path to earth. I presume the other two cables leaving the terminals will be the main bonding to the other services, which will have exposed metal parts also.
You would hope as the installation has been signed off by an inspector that any fault current would trip the RCD
Haha... It was done by council on a contract i was on. They were bit funny at first when it all came off. When we started screwing they moaned about time and cost of screws and plugs.. . It was a case of as cheap as possible and as quick as possible. The old stuff was all left in place with backboxes filled with plaster. I dread to think what happened to that block of flats... Council barely maintained it..
They are there as a direct path to earth. I presume the other two cables leaving the terminals will be the main bonding to the other services, which will have exposed parts also.
Yes I mentioned the RCD earlier, I agree it's not likely to ever become dangerous because it must now have an RCD. But RCD's are not 100% reliable, even if recently tested. It just seems crazy to leave the final part of the earth network of the entire house exposed like that. What is the point?
You may need to think about that healthy old "Bird on the wire"
Then consider why we use cpcs and install bonding conductors to create a equipotential zone, what the fruits of having that zone means for our safety
Edited to give my opinion
Earthing and bonding is the age old and most reliable No 1 safety feature
Rcds are best thought of as maybe being necessary, but they are more of a back up rather than the main safety item
Yes I'm sure there is a reason - I'm just asking (in layman's terms) what the reason is for leaving it exposed, and why it can't ever become live, if there is a fault in another connected appliance which leads to live travelling to ground, via that terminal. And for arguments sake there is no RCD/faulty RCD.
It's an electricians forum - seems like the right place to focus on what is right and wrong with electrical installations, not society as a whole..
I can see by the pics that was put on here .
if the op does not like it he can only ring the council and complain to them and see what they say.
It's an exposed conductive part...The shock protection is provided by automatic disconnection of supply (ADS).
ADS is the most commonly used protective measure and applies to most electrical installations.
Connecting together accessible metalwork of an electrical installation, that is, the exposed conductive parts and extraneous conductive parts which are bonded as part of the protective measure ADS, reduces the touch voltage in earth fault conditions.
Depending on the earthing arrangement the final part (in the house) will either be the sheathing of the incoming cable or the neutral terminal inside the main head. I can’t say I’ve seen a domestic installation where the MET is completely enclosed.
As long as everything remains connected I can’t see that there is any danger
Connecting together accessible metalwork of an electrical installation, that is, the exposed conductive parts and extraneous conductive parts which are bonded as part of ADS, reduces the touch voltage in earth fault conditions.
Thanks that all makes sense. But in an earth fault condition, that would still become live - and would be the last connected conductive part before ground. Does that not make it potentially more dangerous to be in contact with?
Edit I appreciate that no matter what most current will still want to travel to ground, not through anyone touching it - but there is still some low level risk of making contact isn't there?
Everything should rise at the same potential or there abouts. Obviously factors like length/resistance of bonding conductors etc can have an influence. The situation you've put forward is no different to touching an exposed conductive part and an extraneous conductive part at the same time whilst an earth fault is occurring. This is why Zs values, bonding, earthing etc is adheared to as part of the protective measure ADS.
Thanks. Not being a spark myself I have only a limited grasp on how potential works. So in basic terms, yes the entire earth network is 'live' in an earth fault scenario, but anyone touching any part of it has such a tiny potential compared to ground, that they will receive a super low voltage and probably not even notice? And a bird sat on a wire has zero potential so they get no voltage at all.
If you had an Earth fault and the installation Earth was disconnected, then there could be a problem.
This is an earthing arrangement in a larger building. Perfectly safe and normal to have it exposed
The OP came on here for advice and reassurance, fair enough as dodgy electrics can be lethal . I don't understand how one or two here seem to be looking down their noses due to the property being a Council House. We all know that it's become more and more difficult to own your home in recent years and I hate this snobbish attitude.
England
What is this and is it normal? Council electrics
RyanA,
Pete E,
