What is this wire? | on ElectriciansForums
Discuss What is this wire? in the Australia area at ElectriciansForums.net
E
eskimo39
Hi guys, I was at a customers house today and am a little puzzled by his electricity meters.
Firstly he has a standard consumer unit which feeds lighting, sockets, cooker etc. This is fed from the meter via a henley block then fed from the same henley block there is a large metal timeclock which I assume to be economy 7 even though it doesn't look like any images I have seen online. This is in a rounded glass case whith supplier seals and has a large metal clock with 'on' indicated at 12am and 'off' indicated at 7am. This feeds a seperate consumer unit which in turn feeds 5 storage heaters.
Then what is confusing me is there is a small transformer plugged into a socket just next to the mains, this has a sticker on it saying "Do not unplug", this then seems to just have an earth (Green & Yellow) wire from it and a bare silver wire which go behind the consumer unit where I cannot get access so I have no idea what it does.
Does this have something to do with the timer? What does it do?
Thanks in advance
The tinned copper wire is probably the old equipotential earth wire which either went to the main eath terminal or to a steel water pipe under the house; Check continuity but if you dont need to remove it I would leave alone. If at any time the meter needs to be replaced then that's the time to consider stripping it out.
Why would this need a small transformer powering it (Similar to the size of a mobile phone charger) ? Thaks for the response.
CBW am there tomorrow so will take the old camera.
Cheers
By the description it would seem to be an old Sangamo time clock
Is there a screw to slacken,twist the glass case off then pull out the mechanism ?
There should also be a push button on the side for overide.on/off
They also have little day markers that can be turned on/off (if they are the 7 day timers)in a little circular wheel
The in and out connections through the bottom
If it is this timer,they are an absolutely brilliant piece of past engineering skills and very accurate
Well worth keeping
Well worth keeping
Indeed ! my old metering trainer had 160 of these ! he loved them ! the sort of thing an old watch maker would like as well. Built to last !
Reply to What is this wire? in the Australia area at ElectriciansForums.net
Normally you'd install either a fuse-switch or a switchfuse at the incoming supply position rather than a DB, this gives you some hope of...
davesparks
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
